Rb heLp
Rb heLp
ok so hers the situation I have an rb26dett powerd silvia recntly my idle has been acting up when the motors cold the idle would bounce around from around 900-1300 or so. The car would also randomly stall on me while im off the gas comeing to a stop or truning. When the car is doing this odd idle it runs CRAZY ritch and puffs nasty black smoke out the back of the car. About two days ago I hade a flat tire. I went to move the car into my garage when it fired up fine but when I started to back out it stalled I figured this was one of the normal stalls so I tryed to restart but couldint I figured my battery was weak as this is a common problem aswell. so I changed the tires on my driveway where it died. once I was done I hooked the car up to another and tried to start. but nothing happend the car was turning over but the motor isint fireing. I have plenty of voltage to fire the car so power isint the problem. any sugestions on what could be my problem I have a feeling these two problems are linked some how any help would be nice thanks.
