Why do performance turbos make that sound?
Old 05-09-2007 | 04:42 PM
*Chris*'s Avatar
I have noticed from watching a few videos that the high end turbos make a noise when the boost drops, why??
Old 05-14-2007 | 01:51 PM
*Chris*'s Avatar
Does no one know??
Old 05-22-2007 | 01:58 PM
do you mean the sound of the blow-off valve? that is the pressure being released to prevent the turbo from overboosting. this often happens between gear changes as the RPMs drop from gear to gear. you don't want to keep the turbine boosting and boosting and boosting else it will blow up.
Old 05-22-2007 | 10:06 PM
*Chris*'s Avatar
OOOOOHHH, ok thanks for the info.
Old 06-26-2007 | 10:07 PM
k4site's Avatar
there is a difference between a diverter and blowoff value.
Old 10-25-2007 | 10:49 PM
celsius's Avatar
yes, a diverter re-routes the air after the compressor usually back into the inlet of the compressor. Blowoff valve is blown into the atmosphere
Old 12-05-2007 | 04:59 PM
*Chris*'s Avatar
is one better than the other?
Old 01-16-2008 | 02:52 PM
winkie's Avatar
Depends on the application...
Old 02-19-2008 | 02:19 PM
rmatt8748's Avatar
there are two basic types of Blow off Valves (BOV's
Vent to Atmosphere (VTA)
Vent to Intake (Sometimes VTI)
VTA gets that ricey sound often found in movies. VTI is not very good with stock intakes and stock air metering devices. They tend to work better with stand alone ecu's or a properly functioning speed density air sensor
All blow off valves make a sound, usually with stock intakes it is masked, but even a VTI will make a noise that is audible in the cockpit if there is a CAI or ram air intake fitted to the car.
I hope that helps
Old 03-19-2008 | 03:38 PM
gtr_nismo_bc's Avatar
Some of the cool sounding cars are running with out a BOV or recirc valves. That gives that chatter sound or the compressor surge of air being forced backwards through the intake system.
Like in this video.
http://www.youtube.com/watch?v=SX0Z9...eature=related
